Discuss How long after installing solvent weld waste pipe till can be tested in the Plumbing Jobs | The Job-board area at PlumbersForums.net
How long after glueing solvent weld waste pipe, is it needed to set before can be tested? Pretty sure its only a couple of mintues or so.
Guess its more to do with the weight of the water than the psi
Whats a pint of water is it a kilo?
1 ltr = 1kg.
metric is so simple, i prefer inches tho.
Worked it out in the kitchen lol
Rpm. Your "water" is a lot heavier and browner than mine.
At 4 degrees C :grin::grin:1 ltr = 1kg.
568 grams.Guess its more to do with the weight of the water than the psi
Reply to How long after installing solvent weld waste pipe till can be tested in the Plumbing Jobs | The Job-board area at PlumbersForums.net
