Discuss Fixing bath to wall in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Is the bath just pushed up against the tiles (as appears in the picture) rather than tiled off? If so that's bad practice and susceptible to movement.
I batten then and use a tube or 2 to seal them to the wall before tilling but I put a dust sheet in the bath and place a few bags of tile addy inside it to hold it down a touch in my mind it doesn't really do anything but its how I have always done them then after the silicone has fully cured I use a self adhesive tanking tape onto the bath edge about 40mm the I tile or get our tiler to tile the bathroom then wit sharp knife cut the tape back level with the tile then silicone up with plumbers gold
I have fitted several baths and always found the wall brackets were provided. A little awkward to drill into place but worth it for a secure bath that does not move.
I'm fitting our new bath at the moment. I intend to batten the wall on 2 sides.
What is the best kind of wood to use for wall battens?
I read on another forum that roofing battens are ideal because they are treated. However, every piece of roofing batten that I've looked at in wickes and B&Q is bent like a banana. So any other suggestions.
Thanks in advance
I am currently fitting a new bath at the moment. I intend to batten the wall on 2 sides.
I read on another forum that roofing battens are ideal because they are treated. However every piece of roofing batten that I've looked at in wickes and B&Q is bent like a banana. So any other suggestions.
Thanks in advance
Don't buy your batten from B&Q. Much better to use PAR timber from a good supplier. The treatment bit is moot. If fitted badly you will get water ingress so need treatment to protect......treated timber is full of horrible chemicals so should really be avoided in bathrooms etc.
Reply to Fixing bath to wall in the Plumbing Jobs | The Job-board area at PlumbersForums.net
  • Locked
Hi I thought I would try all you experienced plumbers as I am fairly new in the game and I would like some help for future reference I was...
2K
K
  • Locked
Right guys, 1700x900 p shaped whirlpool bath. going into this space . you'll see where the cutouts are, those are where the 2 legs stand...
4K
k13wjd
K
  • Locked
Hi all, Have just spent 2 hours trying to drill fixing holes in a concrete floor today without success. Using an 850W Dewalt Hammer Drill with...
7K
365drills
  • Locked
I've just taken out a bath ready to replace with a new one. The bath was fixed to the wall with two brackets behind the bottom row of tiles. I had...
3K
leakylea
L
  • Locked
Hi all, I'm not new to installing bathrooms, but this one has stumped me. The customer has asked for bath edging strips to be put in on the...
14K
