Discuss Fixing bath to wall in the Plumbing Jobs | The Job-board area at PlumbersForums.net
C
Chris R
Has anyone come across a fixing for baths ? At the moment I rely on improvising with metal strips etc to fasten the bath to the wall. I have often wondered if anyone makes a specific fitting - any ideas
Ta
On most tiles that won't matter as the area of the time is so large in comparison, it will still stick fine. Showers have upstands.
I normally stick tanking tape over the lip and paint it anyway, gives adhesion at the bottom.
UPSTAND - like wot kitchen worktops have - right on TBServices. thanks.
That makes sense, there would be endless configurations of baths and they would become ridiculously expensive as a result.
Fitted correctly a bath shouldn't really need upstands
Which is effectively what happened with Mira Flight trays. The combination of upstands and sizes made it impossible to stock, but all too easy to damage...
my old boss use to make me chase about half an inch into the wall (if solid) where the bath would go , put a tube of silacone around the 2 edges to be fitted to the wall, push it in to place , smooth off silacone, then following day plaster all aroud the chase bath with cement before sealing it again after the cement was dry! cant see why i needed to do the chase! bathrooms took so long to fit then!!( we used the supplied L bracket and screwed 3 of the legs in place aswell)
Is the bath just pushed up against the tiles (as appears in the picture) rather than tiled off? If so that's bad practice and susceptible to movement.
I batten then and use a tube or 2 to seal them to the wall before tilling but I put a dust sheet in the bath and place a few bags of tile addy inside it to hold it down a touch in my mind it doesn't really do anything but its how I have always done them then after the silicone has fully cured I use a self adhesive tanking tape onto the bath edge about 40mm the I tile or get our tiler to tile the bathroom then wit sharp knife cut the tape back level with the tile then silicone up with plumbers gold
I have fitted several baths and always found the wall brackets were provided. A little awkward to drill into place but worth it for a secure bath that does not move.
I'm fitting our new bath at the moment. I intend to batten the wall on 2 sides.
What is the best kind of wood to use for wall battens?
I read on another forum that roofing battens are ideal because they are treated. However, every piece of roofing batten that I've looked at in wickes and B&Q is bent like a banana. So any other suggestions.
Thanks in advance
I am currently fitting a new bath at the moment. I intend to batten the wall on 2 sides.
I read on another forum that roofing battens are ideal because they are treated. However every piece of roofing batten that I've looked at in wickes and B&Q is bent like a banana. So any other suggestions.
Thanks in advance
Don't buy your batten from B&Q. Much better to use PAR timber from a good supplier. The treatment bit is moot. If fitted badly you will get water ingress so need treatment to protect......treated timber is full of horrible chemicals so should really be avoided in bathrooms etc.
Reply to Fixing bath to wall in the Plumbing Jobs | The Job-board area at PlumbersForums.net
