Discuss Faulty float valve, or faulty immersion stat? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
K
kevin plumber
Just inspected a hot water cylinder with a combined water tank, on inspection i found the water tank to have the float valve (part 1 type) submerged in water. The water is coming out of the overflow and i'm drawn to either of the two conclusions:
1. Ball valve is faulty and needs replacing.
2. Thermostat is bust and causing expanding water to pump over, hence the extra water in the tank being sent out of the overflow.
A second opinion would be good, cheers.
1- turn the cold feed of, if it stops over flowing then the valve is the problem,
you don't want a type 1 valve anyway.
2 -what temperature is the water at? wont expand much from 60 degrees until it turns to steam.
what level is the float at when the cylinder is cold?
Think about it.
If the immersion stat was overheating, would the cwst overflowing be the most obvious result??
The float valve is shut off and the water isn't constantly discharging, however the water level is a few mm under the overflow. The float is submurged in water but seems to be shut down.
On arrival the cylinder was cold and the float was fully extended, as in its last point of its cycle if you know what i mean.
I would have thought if the thermostat had failed, the water would expand and pump over?
Either that or the float valve is faulty and letting by?
Thanks for the reply, just needed a second opinion, worst case i will change both if need be!
Well mountain man that is the question i'm asking, at the time i inspected the tank it was cold and will return when the tank is hot to see for myself, but was just asking for a second opinion, not a sarky comment tbh!
Has the float on the valve got a hole in it?
I've seen them with a small hole in the middle. From the friction of gliding across the water for years I guess. Then the float sinks and thus won't float up to close the valve off.
A 90p new orange ball and you could be back in action.
Test the stat with a meter and then you'll know, but it's not likely to be the stat is it?
Its not hard to tell if a float valve is letting by either.
Suck some water out of the cistern. Push down valve to ensure water's coming out. Pull up to ensure it stops dripping. If fine, then ball float. If not fine, then you've probably found your problem.
Compare the plumber dot com
simples!!!
hehe
Could the float have water trapped in it causing the valve to sink? Also is the air-trap big enough ( Distance between water level and overflow to allow for expansion? Thermostat should have a safety cut-out to prevent overheating.
Yeah, I've just re-read the opening post.
Sounds like the ball valve needs a new washer.
They get indented over time. This means they over fill before they shut off.
Some people just bend the brass arm over to get over this. I personally service the valve and change the washer (takes ten minutes tops).
Or just fit a new valve, fiver from Screw Fix.
Hi scotty ive looked at hte air gap which would be between the ball valve and overflow and that is sufficient. Presently with the float submerged, the water level is only mm from the over flow.
I understand that the thermostat 'should' have a thermal cut out, however i did come across one the other day which did not. The water continued to heat and was scolding when coming from the taps!
So check the stat with a meter, and then you can discount it if it's not faulty.
If it was the stat the water in the cistern would be boiling hot and the place like a sauna.
Fit a 5p washer and it is sorted.
Not a sarky comment Kevin, Tamz has answered your question.
I just thought figuring the answer out for yourself might be more gratifying.
i was taught to start from basics.
turn the cold feed of then run the hot tap to drain the cwst.
then inspect what your looking at.
5p washer tamz? i'd have thought a scotsman would advise a valve swap to get a little for the weigh in.....:wink_smile:
With Tamz on this.
Water expands by 4% when heated. 1600% when it turns to steam.
Fit a new Ball valve and ball, and fit a new stat. It would cost you no more than £20 and it will be sorted no problem.
That will solve the problem for sure but will provide no diagnosis of the true cause.
For the sake of probably less than £20 why mess about with it?
There is no need to mess about with anything. It needs a washer, fixed it 5 minutes, minimum charge to the customer.
Quality of service and acquisition of knowledge I'd say.
Anyone can guess wildly, a professional either knows what to do or will make an educated guess!
And how to change a washer is first week in the job stuff. It doesn't come much easier than that one.
Why change a washer if the float is full of water and no longer floating?
I told him to check the float on page 1.
Its now page 3 and as Tamz says, this is basic stuff.
Check the float, check the valve, and check the stat with an electrical meter.
Change the faulty part. The name of the original poster implies he's a plumber. So this should be childs play.
Nobody said the float was full of water, just that it is under the water. This is 1st year apprentice stuff. Anyone who can't properly diagnose this in 2 seconds is in the wrong job.
Couldn't agree more mate.
If an allegedly experienced plumber is still asking stupid questions after a load of sensible answers have been provided it doesn't bode well for the future of the trade IMO.
I do actually worry about how things will be 20 years down the line. Of course there will still be some good tradesmen /women but the majority will be useless. I have really seen standards and skill levels drop dramatically in the past 10 or so years and it gets worse year after year.
I'd better keep my tools with me when i land in a nursing home........if i can still remember what to do with them by then :lol:
It wasnt i wild guess it could have been a problem with the stat or the ballvalve. For the sake of a ball valve and a stat and being 100% sure its fixed and safe whats the problem with changing both? I was just trying to help the guy? is that not what this forum is about?
No way could it have been the 'stat without really obvious indications.
Yes, this forum does it's best to help but when the best advice is offered perhaps it should be accepted and not argued with.
If the information provided is not acceptable then the poster is at liberty to go elsewhere for free advice.
I'd give you odds of 10,000,000 / 1 it wasn't or could never have been the stat.
2nd post by the OP
"On arrival the cylinder was cold and the float was fully extended, as in its last point of its cycle if you know what i mean."
It doesn't need Sherlock Holmes to figure that one out!
Perhaps he'd best change the cylinder as well just in case that's the cause. Plumbing shouldn't be about throwing parts at a job until you get it right. A correct diagnosis should be made and a repair carried out.
Reply to Faulty float valve, or faulty immersion stat? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I have just had a new boiler and 210 ltr unvented tank fitted in the loft to replace a very old Baxi back boiler. I have now fitted a Solic 200...
Hi all I have a problem with my hot water header tank getting warm water into it from the bottom of the header tank (not the hooked...
This sounds like an examination question but it really is a problem two different plumbers have been unable to resolve after spending several...
Hello, I have quite low flow rate for my electric shower (a piddling 5L/min), and would like some tips or advice about how to solve or find the...
Essaboy
E
 Our heating stopped working today. We've got a Veissmann boiler that's under a year old, and an older Megaflow cylinder, and two diverter...
