O
oldnorm
What is the correct way to make a compression joint? There are various views on whether sealing compound should be used or not. I want to replace a defective compression joint water valve which has 3 ports. From past experience, when I dismantle it the original tight fitting olives will remain in place. Should these be removed and new ones fitted. The valve is fitted in a very confined space which makes using a saw to remove olives difficult.
Help would be appreciated.
Thank you.
Thank you.
