Discuss Combi with highest DHW flow rate? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
M
Masood
What's the highest DHW flow rate combi that you know of? I have 25l/min mains and I want to take advantage of that.
Was thinking of going unvented but not really worth it in my flat..
intergas are rather good, fm experience the output is better than they advertise :)
Well, I'm a big Intergas fan already but even the 36/40 has an advertised flow rate of 13l/min @ 35 delta...
I really want to install a Eco RF 36, but 13l/min seems a bit low..
just remember the 36 is the combi max the 40 is the heating max, never got my head around that particular model. your flat won't be needing a 40kw input to warm a few rads!!!!!!!!!!!!!!!!!!!!
Ha! That's the opposite to the others, the higher rate is DHW on all the other HREs. No, definitely don't need 40KW for CH LOL. Was thinking 40KW for water and rate the CH side right down..
nope first figure is hw and second heating, same as the rest.
Yes, and the first figure is higher on all except this one. Should have put 2 and 2 together, durr!
So 36/30 is my best bet. Can set CH power down to 25% from memory, so about 7KW for CH side. Haven't done the heat loss calcs yet but should be about right...
Ideal Vogue 40..cheap boiler for the flowrate,quiet as well..big warranty
Worcester do the green star combi with 22pm might be a bit big if you only getting 25 at the mains.
The Worcester Highflow does give amazing hot water performance. I have only fitted one, the 550, but you could run a bath and have a shower at the same time comfortably.
if those worcesters are the floor standing ones i wouldnt want to get them up masoods staircase let alone in the loft
GW energy 35 store combi 21 l/m twin tank
I was going to instal one for someone last year but it never happened due to price they went for Logic + instead.
Seemed quite good from what I remember bit bulky though, it was going to go in the garage.
I've fitted Atag A325EC in my house in loft space (chalet bungalow) you probably wouldn't want that in your kitchen as also big, water flow nothing special think about 13L but very economical due to built in pre heat been in approx year now so far no probs.
Glow worm ultra com 35 store nearly 20 lpm
Reply to Combi with highest DHW flow rate? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
The left rear floor corner is highest (the shower pan touches/sits on the floor), sloping down diagonally to the front right corner (lowest). The front right corner shim is 5/8", the left front corner is 3/8" shimmed, with shorter shims under left middle and right rear corner. The pan perimeters...
