Discuss Combi with highest DHW flow rate? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
M
Masood
What's the highest DHW flow rate combi that you know of? I have 25l/min mains and I want to take advantage of that.
Was thinking of going unvented but not really worth it in my flat..
intergas are rather good, fm experience the output is better than they advertise :)
Well, I'm a big Intergas fan already but even the 36/40 has an advertised flow rate of 13l/min @ 35 delta...
I really want to install a Eco RF 36, but 13l/min seems a bit low..
just remember the 36 is the combi max the 40 is the heating max, never got my head around that particular model. your flat won't be needing a 40kw input to warm a few rads!!!!!!!!!!!!!!!!!!!!
Ha! That's the opposite to the others, the higher rate is DHW on all the other HREs. No, definitely don't need 40KW for CH LOL. Was thinking 40KW for water and rate the CH side right down..
nope first figure is hw and second heating, same as the rest.
Reply to Combi with highest DHW flow rate? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hello, I have quite low flow rate for my electric shower (a piddling 5L/min), and would like some tips or advice about how to solve or find the...
Essaboy
E
Hi Could I ask for some help with a water flow rate problem. I have good mains water pressure on the ground floor. There is no tank in the loft...
I was looking into a problem with flow rate in my bathroom. A bit confused with how flow rate, water pressure, pipe length, and difference in...
Hi everyone, Just a query about what size in KW gas combi boiler do I need for a top floor flat (3rd floor). I have a Vokera Easi heat plus...
Hi Folks, I have a challenge with a Main Eco Elite 30 Combi which is short cycling on the CH. Water works fine. As soon as you have call for...
