Discuss Combi with highest DHW flow rate? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
nope first figure is hw and second heating, same as the rest.
Yes, and the first figure is higher on all except this one. Should have put 2 and 2 together, durr!
So 36/30 is my best bet. Can set CH power down to 25% from memory, so about 7KW for CH side. Haven't done the heat loss calcs yet but should be about right...
Ideal Vogue 40..cheap boiler for the flowrate,quiet as well..big warranty
Worcester do the green star combi with 22pm might be a bit big if you only getting 25 at the mains.
Reply to Combi with highest DHW flow rate? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
The left rear floor corner is highest (the shower pan touches/sits on the floor), sloping down diagonally to the front right corner (lowest). The...
I have a plumber coming tomorrow to change a cartridge on a badly dripping tap on my bathroom mixer unit. There is no separate isolating valve for...
Hi All I have a leak coming from within my Mira Elite QT shower. It seems to be flowing from behind the switching Control. Any ideas what could...
