Discuss Combi with highest DHW flow rate? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
nope first figure is hw and second heating, same as the rest.
Yes, and the first figure is higher on all except this one. Should have put 2 and 2 together, durr!
So 36/30 is my best bet. Can set CH power down to 25% from memory, so about 7KW for CH side. Haven't done the heat loss calcs yet but should be about right...
Ideal Vogue 40..cheap boiler for the flowrate,quiet as well..big warranty
Worcester do the green star combi with 22pm might be a bit big if you only getting 25 at the mains.
Reply to Combi with highest DHW flow rate? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hello, I have quite low flow rate for my electric shower (a piddling 5L/min), and would like some tips or advice about how to solve or find the...
Essaboy
E
Hi Could I ask for some help with a water flow rate problem. I have good mains water pressure on the ground floor. There is no tank in the loft...
I was looking into a problem with flow rate in my bathroom. A bit confused with how flow rate, water pressure, pipe length, and difference in...
Hi everyone, Just a query about what size in KW gas combi boiler do I need for a top floor flat (3rd floor). I have a Vokera Easi heat plus...
Hi Folks, I have a challenge with a Main Eco Elite 30 Combi which is short cycling on the CH. Water works fine. As soon as you have call for...
