Discuss Bleeding a radiator for the first time in the Plumbing Jobs | The Job-board area at PlumbersForums.net
If you have a combi boiler or sealed system you may have to top the pressure back up , if you have ,
find out how to before you bleed the rad .[/QUOTEyes combo boiler it is . Pressure did fall. Turn the black lever and it went up again.
is there a special screwdriver I can use because where that valve is and the wall it's 3 inches apart.Top right ,the one with the small screwdriver slot
I brought that and there area from the wall to the radiator is 3 inches I need 4 inches space to slot that key in to bleed the radiator. I think I need a quote for a new one.y
I think that might add to the confusion lol
Reply to Bleeding a radiator for the first time in the Plumbing Jobs | The Job-board area at PlumbersForums.net
