Discuss 3/4 olives used in 22mm compression on imperial pipe... in the Plumbing Jobs | The Job-board area at PlumbersForums.net
WaterTight
Subscribed
What size olives do I need - presuming I do exactly the same (???) - to use 28mm compression?
I know I could have said what's the next imperial size up in pipe but I also want to check if it's the same principle for every pipe size up in size excluding 15mm or whether some aren't...
Reply to 3/4 olives used in 22mm compression on imperial pipe... in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I'm a kitchen fitter first and foremost, so occasionally encounter old pipes of varying sizes. From past experience I know how easy it is to...
Hi, I'm trying to connect 3/4" copper to 22mm copper in an old house. However it appears that the 3/4" is actually slightly smaller (measured at...
Do any of you guys use this type of reducer? It doesn’t have an olive and the bottom part of the brass compresses onto the pipe by the looks of...
Hi I've had to cut hot and cold feed to re route for bathroom feeds. The 22mm Copper pipe hot feed is slightly smaller then my 22mm Copper...
A
Hi, I am replacing a leaking push fit flexi tap connector under the bath with a compression fitting flexi. The problem is that the old pipe seems...
