Discuss y-plan new motorised valve fitted - not firing up in the Plumbing Jobs | The Job-board area at PlumbersForums.net
M
moony
as title says.....
its a floor standing ideal mexico - the 3 port mid position valve was fitted today and now the boiler isnt calling for heat - the pump runs, put me in front of a boiler or combi and im fine - but put me in front of a s-plan or y-plan wiring and i'm scratching my head - im due back there tonight - so any pointers or what to look for would be massively appreciated :)
now i dont know if this was an existing problem or a new one since the motorised valve has been changed - new body new head and all wires gone back to the same way as before.
I assume you have put all the thermostats up to max? Cylinder, Room and the boiler? Check for a supply to the boiler..
This is odd. If the wiring has been done according to honeywell's schematics then the pump and the boiler should both have a live from junction 8 in the terminal box, this is fed from the orange wire from the valve, i.e. if the pumps live then the boiler should be too
sorry didn't mean to confuse things, what I meant was if the pump is live then there should be a signal live being sent to the boiler, I believe that the mexico also needs a permanent live
on of the engineers on here has put a wiring diagram up so look for the post and its on it
Just a thought, what model is the mexico? There is a down draught overheat stat fitted to some of them, fitted in series with the control stat. It could be holding it off?
no worrys - sorted now was a clogged up system and i mean clogged!
Reply to y-plan new motorised valve fitted - not firing up in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hello. I've just replaced our old Potterton EP2 CH controller with a Drayton Wiser HubR (& peripherals). The old backing plate wasn't...
Hi all, so things are coming on now at last! New 250 cylinder in loft all pretty much plumbed in. F+E tank binned off, new ups pump, 2 new zone...
3K
I have a home with an oil boiler in a garage turned into a flat, heating both flat and main house, running c plan with two pumps, two motorised...
5K
So, I went to this job yesterday to change over a faulty motorised valve on the hot water side of an unvented system. I drained the system, wired...
