Discuss Wras approved flexi? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I guess a flexi that is used on a toilet supply needs to be wras approved. Even though its not supplying drinking water. But incase the system experiences back flow. Am I correct?
Yes but tbh anything you supply/ fit should be wras approved
I just saw a 500mm flexi in screwfix one with an iso valve that isn't wras approved. Can't think why you'd want one with an iso valve on for a heating system.
Because it's a normal cold water one :D always pipe up expansion vessels in copper
And some people just don't care fitt anything
Reckon most expansion vessels I see have a flexi, thought it was the norm.
IMO , most wras gear is generally better quality rather than the normal Far East junk
Not wras approved though. Thus not suitable to put on the toilet feed? Need a longer one than 300mm.
Thanks is the above flexi not suitable to pipe a toilet up with, because its not wras approved. Cant see the purpose of it, when do you need a flexi with and iso valve on, on a heating system?
I would not use them on heating only on hot and cold supplies stick with the wras approved product generally better quality . cheers kop
Why do you need it that long ?
Have you tried BES? Do plumbing items need to be specifically WRAS approved? I thought that just meant they'd given someone in WRAS a backhander or sexual favours? What if it has a KIWA approval or suitable BS?
Reply to Wras approved flexi? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi, As I need to purchase two new taps for our en suite, I've noticed that almost all taps now come with flexi tails as standard. I've read some...
Hi everyone, I turned my cold water feed off in the airing cupboard which supplies only cold water to my bathroom but it also turned the water to...
Can anyone help me with an ongoing issue I've had since I had an annual service on my combi boiler, which is a Potterton Performa 24. Literally...
Long story short I have a leak from possibly the flexi hose that connects to the upstairs hot water tap. I've switched off the boiler and mains...
Hi All After having pooling water on my drive, I dug down around to find: Black pipe poly/plastic dug 450mm deep spraying water at mains...
