Discuss Will water run through a switched off boiler. in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
Long story short I have a leak from possibly the flexi hose that connects to the upstairs hot water tap.
I've switched off the boiler and mains water and waiting on a plumber but not sure when they'll arrive.
My question is if I leave the boiler off and then turn the water back on so I can use the Toliet and get water. Will the flow still push through the boiler and continue leaking?
Yes it will still flow
There should be an isolating valve under the boiler to turn the hot water off. They may be labeled "cold" or you could follow the water main if you can.
Alternatively if you take a photo and post it here I can tell you which.
Thank you for the reply, plumber attended pretty quick to replace the hose and confirmed everything you said. All sorted now.
Reply to Will water run through a switched off boiler. in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
Hi, I have a Worcester 28i junior boiler that has started to lose pressure, only when using the central heating. When using hot water I have no issue, however, when running the heating the pressure drops. Im looking for some ideas on what could be causing this. I have no sign of pipe leaks...
