Discuss Worcester Greenstar 28i Junior Issue in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi All,
I just have woken up to no heating and no hot water, The bolier is Worcester Greenstart 28i Junior) on the first instance i have checked the pressure on the boiler which was a little bit below 1, i have topped up to a bit below 2, the bolier had solid blue light on it before and after,
I have tried resetting the boiler no luck, i have tried switching it on and off from mains, no luck,
tried putting the thermostat (honeywell cm707 - at least it looks like it) to a higher degree but that didnt start the boiler,
Below the bolier i have the wireless controll from the termostat and once i press the button on it the boiler starts and heats the radiators and the water for a brief moment but then switches itself of,
It does not do any unusual sounds, i cant see any leakage
Off top: i have tried taking a shower while pushed the override button but got caught with the ice age cold water in the middle,
By any chance any of you have encountered a issue like this before, have you got any ideas how to sort it out?
Does it do anything when you open the tap ?
And the thermostat is connecting to the receiver? Does it need batteries?
I have Exchanged the battery for new ones, not sure if it is connected, when i raise the temperature on the termostat it shows the connection icon from time to time,
Is there aby other Way to check if it is 100% connected?
Rip out the wireless technology
get back to basics to lessen the variables and wait for a few years till the manufacturers get their wireless system right, they are just experimenting on householders in my opinion
Need a gas safe engineer out if you’ve been through the basics. As there’s no hot water I’d be surprised if there was a thermostat issue
Reply to Worcester Greenstar 28i Junior Issue in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi bit of a weird issue, I installed a grohe bathroom tap successfully 2 months ago bought from screwfix. Last week the right hand hot tap makes a squeak noise as I turn it on or off, left tap is 100% perfect and noiseless. This grohe tap is like one unit, so no screw notch or way I can remove...
