Discuss Worcester B 30i 25i Ng Filling arrangements in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Rob Foster
Any practical experience of problems with these filling units/keys leaking . And as the bottom cover needs removing I presume one must be GSR
to do this.... All replies gratefully recieved....Rob Foster aka centralheatking
If you’re talking about the slot on plastic cover on the base of these boilers to expose the key “hole” then no you don’t need to be GS. The key design is carp however and often leak
ok so the bottom bit is not classified as 'taking the cover off a gas appliance ' because the products of combustion are not contained in this area of the boiler, but the plastic key thing is rubbish ..as I thought
regards Rob
it's an improvement on the keyed filling loop. It's easy to top up systems but a pain when filling from empty. The lever springs back to the closed position, so you end up locking it open with a screwdriver! I still prefer an external loop.
that contravenes water regulations but hey vaillant do it as well as the rest of the country
So how does your unit comply if not check valves ?
Reply to Worcester B 30i 25i Ng Filling arrangements in the Plumbing Jobs | The Job-board area at PlumbersForums.net
PSxxxxxx
