Discuss Will the new rad pipes work.... in the Plumbing Jobs | The Job-board area at PlumbersForums.net
J
j0n35y
Hi currently having a new bathroom installed and plumber has moved our radiator to another wall. The pipe work has been altered and we have 2 copper pipes sticking out of floor with pushfit caps.
I'm a little concerned because when the heating is on, all rads in house work fine but the 2 pipes in bathroom do not heat up at all. Surely at least one of them should get a little hot?
The floor has been tiled already and I'm worried the floor may have to come up to have a look at pipework.
any ideas guys
there fine they wont heat up as there no circulation and a bit of air in the pipe
Thankyou Shaun, I did think that it could be air, but expected at least a little heat.
nope there wont be as there will be no heat moving from the t's/ draw off/ supplys
do not take the cap ends off
any ideas guys
The pipes wont heat us as they'll have air in them and theres no circulation in the branch of pipe work therefore the cold water wont be replaced with hot water
Dont worry I wont be taking the caps off lol, thanks for the help
Why did'nt you just ask your plumber ,he would've explained it exactly as all the the above replies,and in a fraction of the time ?
after he left for the day prob
Reply to Will the new rad pipes work.... in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Size of bathroom 230cm x 210cm Height 230cm Birmingham Area Initial problem Burst pipe underground in bathroom, concrete. Have had this dug up...
60's ranch, with single bathroom. Tile over concrete slab. Toilet is about a foot from exterior brick wall. Vent pipe is in interior wall behind...
Bungalow built in 2001. All copper pipework (water and heating) runs in channels of expanded foam polystyrene between a concrete floor and OSB...
Hi - I'm a reasonably experienced DIY plumber but just can't work out why the last new rad I've installed is cold - would really appreciate your...
