Discuss will the joists and flooring take the weight of a corner bath in the Plumbing Jobs | The Job-board area at PlumbersForums.net
T
Tony Watling
I have been asked to fit a corner bath for a client but I am not sure if the joist in hes bathroom will be man enough?
I am investegateing the sizes but I think they will be about 3 x 2.
yeh, i think it will be perfectly fine, go for it
disclamier: fuzzy
What size is the bath and what is the water capacity? The very fact that its in the corner is a help as its tight to the wall.
This will tell you what they SHOULD be:
tech2.html
If they are under sized ot r you are unsure you could always coach bolt steel plates through or double up the joists
mate if in doubt run extra timbers under the legs like ud do on a chip bourd floor or 18mm ply and spread the load floor joists are normally
5 by 2 at the least if your close to the wall its more stable as well
your havin a laugh.
is the bath going in the shed?.
no way will joists be done in 3x2!!!
stand 4 people in the corner and tell them to jump, if it takes that then it will take a bath. lath some timbers accross the top to make more rigid.
its the same as putting a elephant on a tree branch and expecting it to hold
thanks for all your comments I will see in due coarse the actual joist sizes and take things from there.
Ive worked on a few old terraced houses in Derby where the joists were 3x2 in the bathroom we had to surface mount five pipes along the walls, it looked realllllly nice.
Reply to will the joists and flooring take the weight of a corner bath in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi, I need some help on this shower drain installation. I’m about to install a corner shower kit in my basement bathroom. But I just found out the...
Hello, and thanks for taking the time to read. I'm trying to work out if the idea I have is practical? The water pressure in my newly renovated...
So I bought my first flat recently (am in UK) and in a bit of a pickle as the bathroom has turned up lots of problems that weren't picked up by...
Hi I've got some upcoming plumbing work and everything is being drained down for it, so I'm taking the opportunity to replace the boards under...
3K
Hello - am hoping someone out there can offer some advice... I've been living in a split level 1st & 2nd floor masionette for two months, which...
4K
