Discuss when you think its easy! in the Plumbing Jobs | The Job-board area at PlumbersForums.net
R
REDSAW
might of dropped a clanger!
customers corner shower enclosure has seen the day with glass hanging out and seals missing.
its a contract customer of mine supplying room lets and i told him be easier to change glass and frame than source and repair seals at a little extra by replacing screens.
trays in good order so dont want to touch that, from wall to corner it is 750mm square so was looking to fit a 740x740mm screen!.
where the hell do you get them from?:banghead:
initiall thought was yes but all advertised at 760mm, then you dont know what adjustment tolerance is!!
hoped ray had some online to advise but cant find any.
where is all those cheapo's sold that we come accross every day?
Usually 25-30mm adjustment but best speak to a merchant or supplier
Arrrrr!
found one..
selco Aqualux 12 year warrranty, 738-758mm ÂŁ77+vat.
got to collect but i/2mile from job, looks a decent one until i fit it.lol
Don't expect too much for 77 quid lol
like for like replacement, dont have to give them a quote for that just do it..if theres no faffing about fitting the bits that is :) might even leave the wall rails in if it allows as there tiled over :( in and out in an hour lol
Reply to when you think its easy! in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi guys, wish i knew this place was here earlier. I had a leak in my shower enclosure and it was obviously on the vertical bit where the side...
Hello All and thanks Lou i did write a reply but it would not let me send it? i am not sure what I am meant to write and I do not want to come...
Hi all I've had a new quadrant shower fitted in my ensuite (complete job, new tray, tiles, enclosure etc) which leaks from both corners. My...
4K
Corner bath - fitted about 20 years ago. It's acrylic, on a metal frame. The feet have sunk into the soft pine floorboards. I have adjusted the...
2K
  • Locked
The saga of the 3 day shower room continues, day 7. So far it should have been 1st day strip out and get shower tray in, adjust pipes for new...
