Discuss what do you think of this install in the Plumbing Jobs | The Job-board area at PlumbersForums.net
stevetheplumber
Subscribed
2.jpg1.jpgstuck right in the eaves pipes all run across in front of the boiler so you cant get in front of it to work as far as i can make out there is no low water pressure switch on boiler so not a good ide for top of the house you have to unscrew a panel just to get in lagged pipe work but not the fittings and theres a filter tucked in the pipe work with the flush out valve about an inch above the ceiling pipework is copper with plastic fittings can only get one hand over to the airvents and you cant unscrew them as they are into pushfit and just spin one handed so cant tell if they are open or shut
three years old was moved up from the cupboard below any guesses whose work it is and how much they charged?
rubbish
diy/non gas safe and 1k
There is such little space left in London, are boilers getting shoved into crawlspaces now with all the spiders?
Put a leaky ballofix valve in incase the the Aav leaks? I've been missing a trick all these years!
you can buy quality ones that dont leak,i also fit full bores to motorised valves,i will often be the one changing them
shaun,like me clearly does maintenance,build in a easy fix
you always need to think ahead, and how can i make this easier to either me or the next guy to change / fix
Not when you can swap them live!
swap them live with 70 dc water coming at you (mind you most dom places dont have auto fillers ;) , least once the pressures gone the water stops)
half a point for hammers yes bg fitted it 5k plus vat and the aavs have the auto shut offs under them you just have to lay on the unsupported pipework to reach them
Even with genuine balofix valves. After a few years on heating. As soon as you use them they pixx out. Then you have to drain down to fix a leak on a valve to fix the initial problem.!
half a point for hammers yes bg fitted it 5k plus vat and the aavs have the auto shut offs under them you just have to lay on the unsupported push fit jointed pipework to reach them
:D post it to bg twitter page and see what they say :D
Climbing over that un-clipped condense line to reach boiler seems like a disaster waiting to happen.
a night mare to work on i cant belive any boiler doesnt fail safe when the water runs outand the stupidity of choosing that model to go in a loft at the top of the house
thomson your righ its hanging in the breeze right where you want to lay to reach the boiler
Reply to what do you think of this install in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Prompted by a surveyors energy efficiency report (and getting grants as this job belongs to a small charity) I've been asked to lag the pipes in...
Engineer has installed several boilers for me. All the condensate pipes have been connected externally into soil stack or rain water downpipe. In...
Had a quote for a new boiler installation. Quote said... Power Flush require and install new boiler, ==== After the boiler was started, it was...
Hello, my Mothers heating failed in the recent UK cold snap. I found the pump was stuck. I have a question about pump orientation. The...
I have started fitting new radiators in my house. The lounge kitchen gets very cold in the winter and is a big room that has previously had an...
5K
