Discuss WC Pan Connection Problem in the Plumbing Jobs | The Job-board area at PlumbersForums.net
G
GSte
I'm trying to install a toilet but the waste pipe and outlet from the pan are misaligned. I therefore think I need a flexible connector, but all the ones I can find are too long.... the gap between WC and waste pipe is 135mm and the shortest connectors I can find are 150mm. Does anyone know where I could buy a shorter one, or how else I could connect the WC and waste pipes?
Sounds like a straight multikwik extension and a offset pan connector would do.
Post a pic of it...:hair:
Thanks for the fast replies. :)
The forum seems to have edited your link, could you pm it to me please?
Here you go:
Thanks a lot for all your replies. :) Tried to post a picture last night and again this morning, but the moderator wouldn't allow it for some reason!?!
Problem solved now, found an ultra-short flexible connector in B&Q of all places, so the toilet's now installed. Again, thanks a lot for all your help!
Reply to WC Pan Connection Problem in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi, I have just installed a combination all in one WC/small basin…. Out of the fill valve there is a small tube which emits a lot of water...
A few years ago I installed a wall hung toilet pan in my last house which did not flush well when disposing of waste solids. The water would rise...
As part of a slow DIY bathroom refit I've removed the old toilet from the original location next to the soil pipe (and obviously capped off the...
Good evening I've came across 90mm cast iron before and used mcalpine extB (90 to 110 extension) But what I have here kind of bellows out to...
Hello, I'm seeking advice on resolving the persistent blockage issues with my downstairs toilet. A year ago, I replaced an 80s close-coupled...
