Discuss vokera linea 28 cutting out at 57 degrees in the Plumbing Jobs | The Job-board area at PlumbersForums.net
ray
good evening ,looking for some assistance, i have a vokera linea 28 combi boiler running on LPG. problem which has just recently started is that the boiler will run until it reaches 57 degrees and then it cuts out.
It will restart when it has cooled down and then it will cut out at 57 degrees again,
i have replaced the high stat thermostat and also the digital pcb board.
There is no error codes when it cuts out and the light is always green.
anyone any ideas , the boiler is for heating my garage and really dont want to spend any more money on it.
any help appreciated
thansk Ray
Reply to vokera linea 28 cutting out at 57 degrees in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi I have a Vokera 15 vhe boiler and all has been running well for the last 6 months since moving in up until a few weeks a go. Boiler throws up a flashing 79 code. Try restarting the boiler straight away but I have to wait 10 minutes for it to cool down before it works. I reset the boiler...
1K
Hi guys, first post here So I have been boxing in a number of heating pipes that are throughout my garage since the boiler was located there by the previous owner, they decided to run pipes all along the edge of the garage floor... I do however have one that goes vertically out of the concrete...
I have a Vaillant ecofit pure, we had it installed about 6 years ago so it's not an old boiler, a new pump was also fitted at the same time. Anyway, I have the hot water set to come on the morning but the last couple of days I've noticed after around 10mins it's cuts out, then after s couple of...
Hi, I'm hoping someone here may be able to help me out with an issue I have with my baxi duotec boiler. Basically, the hot water temperature has been fluctuating quite alot, dropping in temp then raising again whilst showering. I have had an engineer out who has changed the thermistor, but I am...
Good morning all, just a quick one here and i was wondering if someone could give a little advice on their own experience. I don't usually do a lot of installs or a tremendous amount of gas work but obviously when I do undertake these things then I try my best to keep within the appropriate...
