- Messages
- 255
Discuss Vokera Compact 29 HE won't ignite without the case cover seal removed....? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Cheers. How?!check what restrictor ring is in
Cheers. How?!
Flame picture may look beauriful. When running with case off did flame pulse?? If so better get the ID stickers ready.
Just slacken flue clamp off, take out 3 screws on combustion hood, pull forward just enough, BTW 3rd screw is at the back centerIt didn't pulse during the time I was watching it, but I will make sure on Monday!
Thanks Vern, I will remember that advice mate
To get the fan out to clean the venturi, you just need to unscrew the flue hood on top of the burner and slide that out with the fan attached to it. Only need to slide it out about 3-4 inches to be able to get at the venturi. No need for a drain down and no way were you ever going to get at those screws under the fan in the flue hood with it still in place.
Reply to Vokera Compact 29 HE won't ignite without the case cover seal removed....? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
