Discuss Vertical radiator problem in the DIY Plumbing Forum area at PlumbersForums.net
It has never worked since I bought the house earlier this year. I will check for for a dimple or some indicator of the bottom when I return home on Monday.has it ever worked if not have you fitted it the right way round some have a small dimple to let you know that that is the bottom of the rad,
Please see photos attached. Sorry I do not know the make. There are 2 tappings at the top of the rad, one used for the bleed valve; could these indicate the rad is upside down?Can you photograph the rad do you know the make also
That what I thought maybe upside downThe two tappings at top look more like alternative entry tappings that should be at bottom.
Makes no sense to have 2 possible air valve positions.
Ok I'll swap it round sometime over the next week or so and let you know the outcome.That what I thought maybe upside down
Reply to Vertical radiator problem in the DIY Plumbing Forum area at PlumbersForums.net
