Discuss Vaillant Combi Boiler Question? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
A
ApprenticeTom
Hey guys,
just wondering, can you bend 22mm 90's up into the valves or is there not enough pipe left? I know you can with 15 but I've always used elbows, I've never tried it and I'm not sure when I'll get the chance to give it a a go
Only the ecotec plus comes with pre formed bends for flow and return. Ecotec pro only gives you DHW and PRV. I've tried it by bending but there is no room for clipping if you do it.
Can you remember how much more distance you'd need, say I hung the boiler off the wall a couple of inches with a board of some kind? Thanks
Was surprised it took that long
Street elbows will fit into the compression fittings, question DO YOU KNOW WHAT A STREET ELBOW IS ???
Reply to Vaillant Combi Boiler Question? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi, i've got a job with a Vaillant Ecotec 630 system boiler, and i don't know the full history but the house has definitely been extended...
Hi, We have a Kinetico 2020c HE Water Softener, fitted in 2008 in our loft to the cold water tank in a vented system with a conventional boiler...
Hello, bit of a noob question but would someone be able to help me to understand the pipes coming off our boiler. It's a Grant oil combi boiler...
Hi All This is following on from thread I made a few days ago but can't seem to find I'm in a bit of a bind with my CH design where I want to...
My Grant combi oil boiler is giving me quite a headache at the moment. When I returned home last Friday I'd no heating or hot water. An engineer...
