Discuss Unvented heating system, unusual boiler fault in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Pauld1962
DiddlyP
Called to a customer today and the system boiler keeps repressurising on its own ... After I dropped out all the pressure I watched as it refilled ... The filling loop was disconnected at the time ... Customer reports that it's never done it before ... The only way I could stop it was to turn off the cold mains ... !! ... Any help appreciated ..
Combi boiler ?
It's an old system boiler Vaillant thermocompact vu 282/1e ... Unvented cylinder ... Is there a test for split coil and what causes it ... They use the immersion most of the time as solar power is available ..
Drain & valve off cylinder coil in that way they can still use the immersion or Solar for domestic hot water.
The heating system pressure should stop rising. If so it is the coil & you will have to order a new cylinder.
I isolated the F&R at the boiler at 1.5bar and it held .. Once the return was opened the pressure rose immediately and water meter was turning over .
Probably cylinder coil gone then.
Is it a copper unvented cylinder, or stainless steel?
If you are not G3 qualified, just be aware if no isolating valve on mains supply to unvented cylinder, then only install one BEFORE the combination valve. (Between the combination valve and cylinder must not have any valve)
Reply to Unvented heating system, unusual boiler fault in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Boiler is SIRIUS THREE FS 70 Potterton commercial. Situation: We are small building contractors and my labourers managed to damage the radiator pipes during the strip out. Not the end of the world as damages happens. I am responsible builder and paying my bills and to repair the damages if...
PSxxxxxx
