T
TimeServed
Hi, I'm after some advice from you guys. Basically I have been drafted into a job as the client has been let down by the plumbers on site. The job consists of an old nursing home which is being refurbished into 5 flats. No heating, only hot and cold supplies to kitchen, bathroom and ensuite in each of the 5 flats. No baths, only 2 showers per flat. The original plumbers planned to have fortic cylinders and electric showers, but the client now wants mixer showers, which the original plumbers said would be ok as they can add pumps to the showers. Now this doesn't seem a great idea to me coming off fortics. Anyway I've had a look today and I feel that small, 90L or 120L direct unvented cylinders would be a much better option for each of the flats. I took a pressure reading which is showing 4.5 bar. My concern will be that the building has a 25mm poly incoming mains which then splits off to each flat in 15mm. I'm aware that I will need to feed each cylinder with 22mm directly from the mains but I'm just a bit worried about the 5 flats using numerous outlets at the same times. I have recently gained my unvented qualifications so I do not have great experience installing multiple cylinders with one incoming mains. Any suggestions and advice welcome, thanks.
