Discuss unvented cylinders in the Plumbing Jobs | The Job-board area at PlumbersForums.net
nadia69
are all unvented cylinder imersion heater bosses the same size the one i am changing is a 2inch thread also the cylinder is just over 2 years old and the 2 elements have gone already they have a sticker telling you on the stat not to adjust it is set at 60 degrees the one i changed i put it down to 50 degrees (hard water area) bearing in mind they are not that accurate plus or minus 5 degrees, these elements are incoloy and the will not change as they are out of guarantee
You need a g3 qualified engineer . Your legally prevented from working on it as it's basically a 300kg bomb.
Ask them if you can get a titanium one due to the water quality
also advise the customer they need a water softener.
Reply to unvented cylinders in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi All I have a leak coming from within my Mira Elite QT shower. It seems to be flowing from behind the switching Control. Any ideas what could...
