Discuss Unusual Washing Machine Waste Drain in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
J
JamieD
Hi All,
I'm plumbing in a washing machine into our new house and rather than a normal waste pipe this house just has a hole in the ground. It looks as if the hole used to be a 40mm pipe but it has been sawn off at ground level such that the top of the pipe is flush with the floor tiles. This means there's no pipe sticking out to fit a connector on to. Is there a product that will fit inside the hole (internal diameter is about 38mm) and have a normal waste connector on the other end?
Thanks in advance,
J
Need to dig down a couple of inches sorry to say you sure it’s drainage ?
Reply to Unusual Washing Machine Waste Drain in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
I am installing a sink in utility room. Washing machine waste already exists and is the verical pipe with the flexib pipe from the machine poked down the top and a with a u bend at the bottow going directly to outside drain. Is it OK to put a tee joint into the verical pipe and join the sink...
Hi, We have noticed for a while now that when our washing machine nears the end of a cycle we get a bad smell of dirty water in the downstairs toilet which is next door. We have moved the washing machine as we are having floor tiles put down and have noticed that the waste pipe is full of dark...
We have a utility room with a washing machine but no sink. Wife wants sink. There is room to fit one and the waste will connect to wahing machine waste but the problem is in the water supply. Currently there is only hot and cold washing machine hose fitting isolators attached to very short...
I have moved our washing machine into the garage but there isn’t a drain for the waste pipe. The attached image is of the waste pipe with the condensate pipe from the boiler, can I use a tee join and connect the washing machine pipe? The pipe leads outside and is saddled to the main waste pipe.
A
My mum is trying to connect a washing machine and dishwasher in her kitchen. She got a guy out to do the job and he ended up making a hole in her washing machine hose and ramming the dishwasher hose into it, held together with masking tape and charged her 200 quid for the privilege of her...
