Currently reading:
Under Sink Hose Connection Using Washing Machine Outlet
Discuss Under Sink Hose Connection Using Washing Machine Outlet in the Plumbing Jobs | The Job-board area at PlumbersForums.net
M
Minty_Cymru
Hello all.
I'm looking to make a permanent under sink hose connection by using the washing machine cold water feed.
I've bought a Y piece that will split the feed, and now I need to buy all the hose fittings that need to go on to this. I understand that I will need to place a non return connector to avoid cold water contamination, although I would also like to place a shut of valve (tap) between the Y splitter peice and the hose connecitons.
Can anyone recommend one, or at least let me know what size/thread the washing machine connection is so I can find one that fits?
Thanks.
u probs know but you will need a 15mm compression non return valve, 15mm x 3/4 washing machine valve and a 3/4 washing machine hose
Hoselock do a non return valve which I was planning on using (not compression fit).
I just need a stop valve with the same size in & out as the washing machine tap/connector (female one side, male the other).
Just give up the idea and do it properly. The Y pieces are prone to working loose over a period and leaking.
Reply to Under Sink Hose Connection Using Washing Machine Outlet in the Plumbing Jobs | The Job-board area at PlumbersForums.net
