Discuss TRV Question in the Plumbing Jobs | The Job-board area at PlumbersForums.net
A
alig31
Hi I am installing new radiators and changing the TRVs for more modern ones. My question is with respect to the original pipework there is a TRV 'body' in place which the old TRV fitted to. Should I change the TRV 'body' or just screw the new head onto the existing body.
thanks in advance.
AliG
Fire up the heating and see if the existing bodies work, with the head off the rad should heat up.
Presuming there are no existing issues with the system.
I would add if you have the whole valve then I would change the whole thing, no point putting a new head on and the body failing a week later.
Reply to TRV Question in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi I am trying to fit a Hive Radiator valve into my existing TRV valve body to make them automatic so have bought a Hive valve to try it out. I have done this before in another install but the valves were Danfoss and directly compatible with Hive. I am looking for an adapter that will be able...
Would like some help please as my Drayton Wiser system is a mess. I had 2 TRVs in the lounge, one in the main bedroom, the rest of the house - 6 other radiators and 2 bathroom towel radiators are just normal valve s. We live in a 4-bed, 3 storey house, as converted loft. Common problems were...
Hi - I'm a reasonably experienced DIY plumber but just can't work out why the last new rad I've installed is cold - would really appreciate your help please. I've extended an existing 'run' of radiators - the last one on the run ( in downstairs kitchen) is cold. The first rad added is...
I have a Nest thermostat in my hallway which gets affected by the front door opening and closing. This thermo operates one zone (downstairs). I have one radiator the other side of the door to thermo. I have another in the study and two more in the lounge. None of the radiators have a TRV and...
Hi, I just moved into a new house and it has a Glow Worm Compact 24c combi boiler and a ESI ESRTP4RF+ programmable room thermostat and I am wondering if it's worth turning on the optimum start and stop features? There is also something called TPI (chronoproportional control) but I'm not sure how...
