N
Nick Ajimal
I have a TRV on a bedroom radiator and the rad works when the TRV is set to full, however if I turn it down anything below full the rad switches off altogether. The TRV is a Drayton, however I had the same problem with a Lifestyle valve which was on the same rad and I changed as I though the valve was faulty!
Not sure if the valve is on the flow or return, do I possible need to turn the valve around so that it operates the other way around (hope this makes sense!)
