Drip001
Not sure if anyone can help, the wife ran the shower when we had a mains water supply failure for a minute or so while looking for a reason as to why there was no water coming out.....! so the waters back on but the shower will only run cold water and the low presure light is on. It has three temp settings on the front. The two set for hot the low presure light stays on but when you turn it to cold the low presure light goes off, when running the taps it all works normally and plenty of pressure.
Be good if I could sort this without spending on a new shower. Thanks
