Discuss Toilet leaking from connecter in the Plumbing Jobs | The Job-board area at PlumbersForums.net
K
Kala1000
Hi there,
any advise please, I have install a new toilet " Asix back to wall pan" from ebay.co.uk
is a modern design that is waste ceramic elbow has only half inch gap to the floor, the center exit hole is 1750mm from floor.
The toilet waste is 100% in line to soil waste pip.
I am not entirely sure whether is condensation or leak, but when leave a flat paper sheet under the toilet it get wet but it's not constant leak, I think this should be dry completely and as its concealed system I am worried this may eventually gets worse.
I have change 4 connectors now " mcalpine macfit straight connecter" every time I've change to new connecter, I leave flat paper sheet to test it stays dry until 24 hour " while we using the toilet" then it gets wet,
the toilet supplier kindly sending me a new toilet, but still not sure if this toilet will actually work for us, any tips please!
thank you,
Any chance of a few pics please?
Dont assume its coming from the outlet , just check its not coming from the inlet from the cistern , and dripping down on to the outlet , its a popular leak
we need pics, make sure the ceramic sealing area of the flush pipe {top} are smooth and round and the same for the area where the pan connector seals, iv had toilets that wont ever seal because the sealing surfaces weren't good enough,
Reply to Toilet leaking from connecter in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hello, I'm seeking advice on resolving the persistent blockage issues with my downstairs toilet. A year ago, I replaced an 80s close-coupled...
As part of a slow DIY bathroom refit I've removed the old toilet from the original location next to the soil pipe (and obviously capped off the...
Hi Just had a new bathroom installed with a toilet bowl that reaches the back wall. Its has a bottom entry cold feed to the cistern. The fitter...
Hi sorry im a newbie, pls help if u can. I had a new bathroom installed about a yr ago and since then when i flush the toilet the room stinks of...
Hi all Relatively inexperienced homeowner here. Apologies in advance if I get any terminology wrong. Today I noticed some limescale accumulation...
