Discuss tile keeps slipping! in the Bathrooms, Showers and Wetrooms area at PlumbersForums.net
hi all
i was attempting to install the tiles today on the wall. if you look at the photo, i started at the pipe work as that was the most intricate. problem is, it kept slipping an inch, very frustrating. in the end i gave up and manged to save the adhesive (ready mix) I'm betting its something simple I've overlooked. how do i stop it slipping?
thanks
Wall doesn’t look like it’s prepped correctly and reckon tiles could not stick altogether anyway. If you’re tiling an unsupported tile then usually a timber batten fixed to the wall to keep them in place until you’re ready for the next course.
thanks for your response. what prep would you add? i would have liked to add a tile backer board, but 6mm is too thick and by the time i add adhesive, the tiles would be proud against the rest of the existing tiles
Slipping your working from the bottom up arnt you with spacers etc and enough addy ?
Seems like the wall is not well-prepped.
First, use a flat scrap of wood to even and smoothen out the surface and let this dry for a few hours or overnight. Once the cement is dry, apply the bonding agent that should give the surface a rough texture to ensure vertical tiles don't slide as you work.
hi all, thanks for above. i have roughly 20mm to fill (the tile is 5mm thickness leaving 15mm) i can't get hold of 4mm tile backerboards. taking in the advice above, i was thinking of adding thickness to the wall using rapid set cement mix. what is the maximum thickness of adhesive to use? based on sundays attempt it seems like a lot of adhesive to use, unless that doesn't matter.
what do you think?
Reply to tile keeps slipping! in the Bathrooms, Showers and Wetrooms area at PlumbersForums.net
Good morning! First post looking for advice on an issue I am having with a bath installation. Although I have installed many baths before, mainly...
Hi, Today I noticed one of the tiles in my shower enclosure has a crack in per the pictures below... I'm not sure how long it's been there but we...
    • Informative
Anyone involved in tiling a bathroom won't go far wrong using this adhesive , it's easy to mix with the power mixer, stays useable in the bucket a...
Aquarius
A
Hi all, We recently had a ground floor bathroom/wet room finished off, It's about 3.6m long by 2.7m wide, tiled from floor to ceiling and has no...
5K
I have a Worcester Bosch 24Ri regular boiler (open vent) which is 10 years old. It has been pretty reliable with only one fault (the fan unit...
