How do you mean? extract from the shower to the main room?If shower doesn’t clear you could extract from it just into the main room and let the beast clear it.
Discuss Condensation In Bathroom With No Window - Best Extractor Solution? in the Bathrooms, Showers and Wetrooms area at PlumbersForums.net
100% get rid of flexi duct. I won’t even use it for a meter run.
How are you going to change the ducting?
PS I do think you should talk to the installer so they are aware of the issues you are having, so they can learn
If you think it’s bad now, just wait until the winter
Sure - but if the problem is fixed, i'll stop there.Flexi vent is 100% rubbish on anything other than runs that are short or need to go around corners
concorde was shaped as it was for airflow reasons
We appreciate your replies/updatesSure - but if the problem is fixed, i'll stop there.
if it comes back with a vengance in the colder months as you rightly pointed out - i'd swap the ducting then I guess.
I thought you said the red lines were marking where the vent runs ????????
extractor fan swapped over to a Vent Axia Lo Carbon Quadra, Centrifigual type extractor fan.
At maximum speed setting (220 m3 per hour), it is preventing moisture in the room, but by god is it loud, its deafening when you're in the room at round 50decibels.
You haven't been using it for long enough to draw any conclusions - and remember its a warm dry time of year
20 minutes minimum for the over run timer IMHO
Reply to Condensation In Bathroom With No Window - Best Extractor Solution? in the Bathrooms, Showers and Wetrooms area at PlumbersForums.net
