Discuss Thermal store - very low hot water pressure. Help/ideas in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Very low (trickle) hot water pressure at outlets. Albion mainsflow indirect cylinder. Help and ideas please!
I have had one similar issue. Had been heated by solar, coil scaled up inside. I disconnected mixing valve, added an elbow and a length of copper to the top section of the coil and kept pouring in a strong lime scale remover. It was so bad it took me several hours. I did plug the bottom for a while to give it chance to eat away the scale. The only other option new cylinder.
One question though did you try just adjusting the valve to only have cold through? if you have full flow cold through, there is your answer.
good luck.
good luck.
Get someone who is g3 qualified out eg unvented they should know what there doing
Reply to Thermal store - very low hot water pressure. Help/ideas in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Can anyone remember the Mira mixer shower that would work down to a really low pressure on a vented hot water system without a shower pump?
Has anyone one fit or serviced one of these before; Heatrae Sadia 25l 9004010. It a 25 litre hot water storage cylinder.
