Discuss T4TS plumbing scenarios in the Plumbing Jobs | The Job-board area at PlumbersForums.net
hi m8 senario 1 a col;d water system check i done every thing on it and still cant how 2 find out how 2 doing it it really got my head messed up
Hi This is what you need to do to complete S1.
1) Go to Loft, remove lid from cold water tank, isolate water supply, switch to bathroom turn on hot water tap, switch back to loft replace float. Inspect 4 items in the loft. Replace lid(s) back on tanks.
2) Switch to Bathroom turn off hot water tap. Inspect 6 items.
3) Switch to Cloakroom Inspect 4 items.
4) Switch to Kitchen Inspect 5 items here, Before inspecting all 5 items you need to open the draincock, freeze the pipe under the main stopcock get the main stopcock replaced, close the draincock, unfreeze the pipe and thats scenario 1 done.
Remember in order to replace the main stopcock the issue in the loft needs to be resolved first.
If you need further help with scenario 1 or any other scenario let me know.
Hey all
Same here im stuck on scenario 3 on the soundness check...judging by the dates on the last posts to this thread you guys should be qualified by now?? how did you get on?? Ive mamnaged to do everything correct apart frm attempting a cold and hot water soundness check... as for scenario 2 you literally need to click on everything to do with both the hot and cold water system and turn all isolation valves off and back on again also turn off the immersion heater as its a waste of energy (only needs be on for baths) and adjust the temp on the thermopstat which is erroneously set to 90oc back to the coprrect temp of 60 oc ..all hot taps must be 60oc and cold taps i think are 20oc...
and help is appreciated with the soundness checks.. train for Trade skills plumbers course material
how did you do soundness test i have done it .it means pressure test.put your arrow on the washing machine pipes and look at what it says
Turn the water on. If it is running through the ceiling the client will be onto claims direct.
soundness testing is in jtl book also
pretty easy really, unless you have a leak and as tamz says, get insurered lol
hi i have done everything on scenario 1 accept a complete cold water system check i cant seem to find them all
Finally completed scenario 3. soundness test. thanx 4 the help. Really have to search with the mouse and the graphics movement isn't good so the option wasn't appearing to connect pressure kit. thanx anyway
Hello, this is music to my ears!!! Could you possibly enlighten me as to how you did this. If you can remember!!!
Many thanks
Jason
Just bumping this to bring all contributors to the attention of all the threads we have on our forums about Train 4 Trade Skills.
There have been A LOT of people who feel they have been missold courses by Train 4 Trade Skills. Many taking legal action.
Please see this for electrical course threads on our sparky forum: https://www.google.co.uk/search?q=t..._cp.r_qf.&fp=37fc7606ff53045&biw=1500&bih=958
This for plumbing course threads on our plumbing forum: https://www.google.co.uk/search?q=t..._cp.r_qf.&fp=37fc7606ff53045&biw=1500&bih=958
I have contacted the tutor team and sent instructions on how to complete scenario 2 and it's still telling hot water check not completed! this is getting to me fed up with it, as I have a general idea of plumbing and know if this was a job a full check would have completed already this is beginning to feel like a joke
Interesting first post there Kirk. Think you may have better luck raising the dead though. lol
Reply to T4TS plumbing scenarios in the Plumbing Jobs | The Job-board area at PlumbersForums.net
