Discuss T&P valve leaking? Santon Premier Plus in the Plumbing Jobs | The Job-board area at PlumbersForums.net
C
ccwh70
I noticed a dripping sound about an hour ago. I went to investigate and noticed water dripping out of a pipe attached to the T&P valve into what looks like and overflow. Unfortunately the water has started running down the overflow pipe side maybe due to a blockage or maybe a untight connector. I guess I'll need to call a plumber tomorrow but I wondered if it was safe to have the heating on and leave the water heater off or if we have to leave it all off until it's checked?
Also, any ideas why it might be leaking? The house is 4 years old and the heating and water don't get heavy use.
Hi, welcome along.
this is the unvented hot water cylinder, yes.
as you suspected, you need to call a plumber, but he has to be qualified to work on unvented cylinders!
you are best to not heat the cylinder any more as that will just add to the problem.
Yes I would defo leave the HW off, you should also have a ball valve or stop tap at your cylinder to turn off the water providing you can positively locate this , you are ok to turn the water off, you MUST turn the HW off at your programmer
HTG on ok, if you ring round in the morning , make sure you find somebody that has their g3 unvented qualification , you could also put a post on here looking for somebody , some great lads on here. Most of them are on all night lol .
Hi, welcome along.
Sound advice...make sure the plumber attending is G3 qualified.
Reply to T&P valve leaking? Santon Premier Plus in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I have discovered a very old end feed 22mm t connector under the bath is very gently weeping water. It’s in a place and with pipework that are...
M
Hi, I've got a brand new (2nd hand) Bosch Hydropower 16H tankless hot water heater. Since it was installed I have noticed it leaks a lot. I took...
Good evening, I'd like your opinion on something that is worrying me please: my landlady's plumber replaced the bottom/night element of my...
Hi, I need some urgent advice. I've Just come home after going out for evening, to discover hallway floor and kitchen floor covered in water. On...
B
Hi everyone, I have a Santon Premier Plus PP120E (unvented direct immersion heater) fitted with two thermostats, which provides hot water to taps...
Bridog
B
