Discuss Strange radiator problem in the Plumbing Jobs | The Job-board area at PlumbersForums.net
L
LindseyS
Hi all,
I am hoping someone can give me some advice - I have a strange problem with some of my radiators being cold.
I rented out my cottage while working away, and the tenant decided to turn off all the radiators at the valve. The boiler (gas gravity system running 7 radiators) I know is fine, as it just went through a landlord annual safety check and service right before the tenant moved out. However, when we switched the boiler back on and turned the valves back on, four of the radiators heated up fine, but three were stone cold.
There doesn't appear to be any air in the system, and the whole radiator is cold, so it's not that they need bleeding.
It's been suggested that they might need desludging, but someone else has since suggested that a sludge problem would give a similar effect to air in the system and the radiators would be partially warm.
If you push in the valve you can hear the flow change, so there does appear to be flow. Also the pipe going to each radiator is hot.
I know a bit about plumbing but not enough to work this one out - I am totally baffled. Any suggestions would be really welcome.
Many thanks
Lindsey
trv pins might be stuck / not open full or as you say sludge
can you feel any warmth on the return pipe work out of each rad?
Welcome to the forum Lindsey.
Could it need balancing guy`s & girls?
could be but depends if the tenant has just turned the trv heads off or messed with the lockshield as well
Which we don`t know hence why I threw it in.
not shooting it down mate hell they might even be shut off seen that a few times :D
Know you didn`t shoot it down Shaun, guess I`m getting involved where maybe I shouldn`t but like I say just threw it in after the welcome along.
Worth balancing the radiators and testing all TRV pins... Take it easy though as the pins can spring out and you'd get a little sprinkle all over your lovely carpet!
its good advice your ok
btw im catching you :D
Hi Lindsey
You say you have "gas gravity system running 7 radiators " do you have a pump on the heating pipework or is it indeed a gravity system? if so who fitted the TRVs?
Either way have you tried turning off the rads that are getting hot?
Thanks guys!
This just gets weirder - some changes seem to have happened while I was out at work today!
The lounge radiator is now cold on inlet and return pipes, but that may be because I've hd to turn the gas fire on in there, just turned the main thermostat up to see what happens.
Spare room radiator is as it was - radiator stone cold, inlet hot, return cold
Bathroom radiator is now hot at both inlet and return, and has stumbled up to lukewarm.
The valves seem to be moving fairly freely on both the lounge and bedroom, the bathroom one does feel a bit sticky. I guess feeling free and being free are two different things though!
On cold rads, fully open lockshields, (opposite end to TRV) then close all rads but one and see if it gets hot. Do this for all cold rads. If cold rads become hot by this method turn on all rads and balance system.
The central heating does have a pump (sorry my terminology's not great, I about know the difference between gravity and combi) :)
Chris, we did turn off the ones that were hot to increase pressure to the others when we first came back on Thursday, but it did nothing - I will try it again now though as the bathroom rad is hinting at signs of life.
The system was in when I bought the house in 2014, I know it was professional fitted but not who by.
Ok we sprinkled the carpet :) But this is so weird, water seems to be coming out fine - with the lockshield open, opening the TRV on the cold lounge radiator pushed water through strongly.
On a bright note, it was nice clear water, not black and dirty - which I guess is good news for both a power flush and the carpet :)
The gurgling coming from the boiler room is making me think airlock - as it doesn't appear to be in any of the radiators, maybe in the pipes?
When I said open lockshield you where meant to turn spindle in anti clockwise direction, it sounds as if you've undo the lockshield, please tell me I'm wrong.
The lock shield is fully screwed anticlockwise, we checked the ones that were working to see how they were sitting first. Hubby just wanted to check there was flow - which there seems to be. It's baffling him as he tells me that everything seems to be implying there's flow either end but nothing going through the radiator - which seems to defy everything I know of the laws of physics :)
If rad is getting hot there is flow. If rad stays cold no flow, assuming no air in rad. Very often if rad turned off for period of time a small amount of sludge can prevent flow but once circulation established everything fine there after. Good luck with your endeavours.
I know it may a stupid question But can you feel if Pump is working ??
Has op tried opening one rad at a time to force through? Start with ones that don't work & open others up.
See concurrent thread,"Central Heating-Possible Blockage", Much good advice, may be applicable.
Bleed circulating pump by loosening central screw. Air in pump will effect performance and damage pump. Your mention of gurgling noise warrants investigation.
Not sure it warranted a PM however, guess we are Yin & Yan as in Quality over Quantity. :smile5: And stop stalking my post count surely you have better things to do. lol
Didn't want to put the topic more of topic :D
Reply to Strange radiator problem in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I want to swap a K1 radiator with a P+, the same size on a combi system. Can i turn off both valves, remove the existing radiator, put the new one...
Hi All, In Dec 2023 I had my annual boiler service and asked the plumber to change 2 radiator valves as the radiator in the toilet downstairs was...
Hi, Sorry if question already answered in previous posts, but I can't find a solution to the below: We recently moved house to a new home that...
Hi all. Could someone help with a issue I have been having with my vertical radiator. I have one vertical radiator in my bungalow and it does not...
Hi to all, I have bought a new radiator as replacement for old one. After installation by plumber, the new radiator is heating up only to 1/3...
