Discuss Space below cylinder? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Replacing an ancient copper hot water cylinder. The airing cupboard has a fully boarded floor and the cylinder is supported on three bearers, resting on the floor, each approximately an inch and a half wide by two inches high. I question whether bearers are needed? Can I just put the new cylinder on the floor or is there a good reason why a space is needed below the cylinder?
The cylinder needs to be on batons to ventilate the bottom to stop corrosion.
Seen plenty pin holed at the bottom when sat straight on the floor, especially on concrete.
Sorry ch 4 totaly disagree, stresses the cylinder.
how many old cylinders do you see straight on the timber boards and these new unvented cylinders you put straight on the floor as well
Very rarely see a copper cylinder straight on the floor, unvented cylinders should be sat straight on the floor no question about that.
Yep agree not straight on to concrete, its similar to why we put cwsc's on solid bases with 150mm overhang, they are fully supported.
I was always taught to have vented cylinders raised to allow air circulation
I was taught it was to stop the cylinder sweating? Always done it and never seen a cylinder suffer for it.
as an apprentice on new build sites back in the day, we always put the cylinders on 3x2 battens made into a cross by the joiners.
Many copper cylinders over here are on batons. I prefer them that way so you can look below them with an inspection mirror. Ideally should be 2" high.
The actual base on a standard 18" diameter cylinder is only about 13 or 14" diameter, so if you use 3" or 4" width batons there won't be much of the base ring not supported.
Never seen a copper cylinder fail due to batons fitted
A copper cylinder should really be raised a little anyhow if possible, whether batons or a raised flat board. The bottom connections of heating coils tend to be no more than 100mm to centre, so that would mean a stub of a pipe to tee onto for the coil if cylinder not raised.
I think it must be regional. I've not come across it at all, although I have seen a whole load of differing "strengthening the base" solutions for both cylinders and CWSTs.
I'll ask one of the cylinder techies next time I see one.
Yes Ray, probably is regional. I do know that there was a recommendation here for cylinders to have 2" timber below them.
Other things are regional. For example, waste pipes tend to be virtually all push fit over here, done last 30 years. Shows plumbers just copy each other perhaps. We do tend to look at other plumbers work I guess.
We use Willis immersion heaters here - very popular and been produced probably 60 years. But it was local invention.
ooo push fit hate the stuff cant beat glued
Yea, I agree. Push fit is more than good enough for waste pipes you can access, for below kitchen sinks, etc, but I don't like it long term below floors - especially if it is not clipped & supported well. To be fair to push fit wastes, I have never had any bother with my work as it is fitted well and on any add on work in later years I replace the fittings.
Solvent weld I used years ago (Marley) and obviously on 110mm pipes nowadays.
I would prefer the option of using either. Solvent weld pipe tended to be brittle from what I remember
For anybody whos interested, i have just spoken to a pal of mine who is the tech guy at a leading cylinder manufacturer.....
They always advise a solid base for all cylinders, but he says there are no hard and fast rules.
is that for unvented cylinder or just normal copper ones
He said all cylinders. He also agreed with me it did seem to be a bit regional, and had heard of them being put on battons.
Solid base for me everytime lol
Cheers TFJ in light of that I'll use one bit of batton and balance the cylinder on it haha :rofl:
all the old cyls I have replaced that pinhole are on solid bases, all those on battens seem to go on forever, never replaced one on battens yet, so I'll be continuing to wack em on battens.
Where's the job security in that?! You want the installation to last long enough so no-one can blame you, but short enough that you get regular work...
Isn't that how boiler manufacturers design boilers there days?
Yes I agree with best
Over here always see timber under a copper cylinder
And push fit waste pipes
What about this space lol
ive never seen one on batterns
see a lot of push-fit. everyones too tight to buy glue
Thanks for all the discussion. The answer to my question seems to be yes ...or no! I do appreciate the comment that putting a cylinder onto, e.g. a concrete floor that might harbour moisture, might well lead to enhanced corrosion if the cylinder is allowed to go cold and water condenses on it. I think that I'll go for the safest option which would be to use a sufficient number of battens to spread the load and avoid cylinder damage. Many thanks to all respondents for your useful advice.
Yes its gone on a bit lol, if i was you , a quick ring to the cylinder manufacturers would be best, go on their advice.
Just put something under it, piece of ply. If you put it straight on a concrete floor, the concrete will eat the copper.
Reply to Space below cylinder? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hello, I am renovating a small bathroom in an apartment on the 5th floor. Heating is electric, no gas or oil. I have four (related) questions...
Background I have a small one-bedroom flat in the roof space in a victorian house. There are three floors below and each floor has a single...
So I bought my first flat recently (am in UK) and in a bit of a pickle as the bathroom has turned up lots of problems that weren't picked up by...
Hi new to the forum here and after some advise please. I have done a garage extension and need heating in the room. I am in a town house with no...
3K
Hi there, thanks for your time to look at this record long post!! I work on the operational management side or a small building contracting firm...
1K
