Discuss Some sort of mould on compression fittings in the Plumbing Jobs | The Job-board area at PlumbersForums.net
stratplus
Anyone came across this before on brass fittings stored in shed. Any suggestions on how to remove it. Tried wire wool, cleaned in hot soapy water and left to soak in boiling water. Anyone know of a chemical that could remove it?
Wire brush, the wheel type with a spindle that fits in a drill? Thinking it`s just oxidisation from damp.
Or it could be rat piddle as its only on a handful out of a box full. I do have a wire brush but was hoping for a solution that's a little easier :)
It can`t get much easier than a wire brush, isn`t there a chance that harsh chemicals could damage the seat where the olive seals. Didn`t think about rat pee tbh but still oxidisation none the less.
Good point. I'll dig the wire brush out and give that a try.
Reply to Some sort of mould on compression fittings in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hello, recently our boiler stopped working properly, causing a lack of heat in our 14-radiator splitter in 3 storeys. having only one boiler at...
I have read a few threads including one by Debbie Stano that were similar to my issue but that thread stopped a while back without any resolution...
I wonder if anyone can help, I've tried several plumbers merchants to no avail. I have removed an old stopcock, (which seized long ago, with a...
2K
So, I went to this job yesterday to change over a faulty motorised valve on the hot water side of an unvented system. I drained the system, wired...
5K
