Discuss Soldering new pipe to old painted pipe in the Plumbing Jobs | The Job-board area at PlumbersForums.net
jaydebruyne
So,
The story goes like this:
Went to fit a new rad today but plumb centre gave me a double panel instead of a single and because I was in a rush I didn't clock this error. I just stuck it in the van and went to the property.
Anyway, drained the system, put on shiny new valves and hung the rad to find out that the tails are 20mm out to the pipes. So I bend myself 2 20mm offsets (first time by sight and spot on might I add, quite proud of that!) and look at the pipe and it's screaming at me "solder me and I'll swear I'll leak!".
I know I can put some heat on the paint and scour it off with some wire wool. But is it really alright to solder???? Would a compression coupling be better??
I didn't finish the pipework in the end as it got late and the tenant needed to go out. But I'm going back on wednesday to finish it off.
So I'm asking for a few tips regarding soldering old pipe to new, or if compression couplings would be better?
Cheers
I just use grips and a cleaning strip to get paint off the pipe, I use my blowtorch if it is really bad. Once the paint it off and the copper clean then it is absolutely fine to solder on to it,
As long as you get it down to clean copper and use a good flux there is no difference in soldering new or old.
I use laco. I used to use the other one in the yellow tub (can't remember the name) but I find it's not great. Lack takes the solder a lot better in my opinion.
But thanks for the assurance. I'll solder it then ;)
If you've never tried it next time grab some Everflux white tub blue lid. In my opinion it walks all over Laco
I've always used gas pliers to strip the paint off. And powerflux is the daddy of fluxes.
Best way to strip paint off pipes is to burn off til pipe is red hot then grab hold and rub wi fingers til the prints gone off em :))
im a scraper either the stanley knife or the back of the junior blade will take gloss of in sheets contary to rumours i no longer carry a shavehook
Use map gas on old pipe if it still has a bit ov water in it
I use mapp. But I've tried soldering with water in pipe and it doesn't solder well :/ how do you do it?
i use sanding mesh from stoolstation , if that doesnt do it then knife / grips with heat
the suck water out with either wet vac or syphon pump thing
Oh ok, yeah I use my wet vac to suck out the water, but I find for some reason the pipe keeps filling - patience was never a virtue of mine :p
works better if you open pipe somewhere else ie if you had a length of pipe capped 1 end, vacuuming the other end undo/take off cap to let air in
Don't the bleed valves on rads do the same thing?
If pipe is open more air gets in , so water clears faster i find anyway
Also put the vac hose over the pipe then block the vac hose with hand or a rag so it just sucks through the pipe
Don't know if you do that already or not
any method of removing the paint will be fine. If its not to close to finished surface then use a torch to help ther paint peel/ loosen. A scraper, pair of grips or whatever to remove the major amount of paint then a abrasive to clean the metal surface. Wipe the pipe clean with a damp cloth and solder as normal.
If the pipework is full of water then a wet vac is prob the easiest and cleanest method to remove that last bit of wata. For some reason these job always seem on cream carpet.
use the flux your comfortable with, if you want to try another flux do so on fittings that are easier to replace/ fix on a less important job.
i just usually put at bit of wire wool between my buttockd,sit on the pipe and turn the music up loud on the radio..If you are tuned to rock fm ...you will find cleaned in no time..classic fm can drag it out a bit though....
:45:
Thanks AW heating.. I'm having to cut quite close to the floor so I'm a little nervous about getting it wrong! But I'll take my time to make sure it goes ok ;)
Little tip:
If you have a pipe that you've cut into that runs vertically, say a pipe coming out of a floor to a rad and it still has abit of water in that can't be drained out. Grab a cleaning product bottle you know the ones that have a spray nozzle on them. Slide that down into the pipe and spray till theres nothing left. Then you can solder away :D
Reply to Soldering new pipe to old painted pipe in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi, Short version: I have about 4" of pipe sticking out of a concrete floor in a cupboard. It makes a 45-degree bend as it exists (bent, not with...
So I think I've made a really stupid mistake. I stuffed a bit of rag into the pipe end to stop drips while I was preparing to solder. Then I put...
Hi I've had to cut hot and cold feed to re route for bathroom feeds. The 22mm Copper pipe hot feed is slightly smaller then my 22mm Copper...
Hi all, Have got an old 60/70s PVC soil stack, the Toilet is going into a Hunter branded socket which has an old O-ring design (quite flat with 3...
