Discuss Sok it to me ********s!! in the Plumbing Jobs | The Job-board area at PlumbersForums.net
never had an issue with them yet, so can't comment on their unreliability, as with all kit, it's normally installer error that is the issue.
Other than the udderly ridiculous condense trap and the jig at the bottom, they're no worse than a DuoTec.
condensate !!! trap, doesnt have any washer or cap that can leak, which is a bonus in my mind and the jig could be better, but I prefer to use robo kits where possible to avoid the need for a jig at all, or if needed use the jig case to run pipes up the rear if needed.
Thought had already uploaded this one.
Could of connected up the machine for em as well
Not gonna work with gas capped? Bit of a basic fault? But a spirotec? Crossovers look tidy. Would have run hot round under flow parallel to gas and tied it in higher up and fitted a doc .
Photo0041.jpg I have upped this before. tis a solid fuel/gas boiler/thermal store combo. the laddomat valve and quencher are next to the wood burner. btw the flue is running up behind a stud frame and accessible.
Reply to Sok it to me ********s!! in the Plumbing Jobs | The Job-board area at PlumbersForums.net
