Discuss Shower tray sealing tapes in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
Just a word of caution the cheap 250mm wide panel is really not good it punctures super easily and is second rate stuff. Looks nice new. I have used classi seals a lot and I have taken baths and showers out with them on and it's pretty resilient stuff. Tiler can still tile over it as it only sticks up 50mm or so
What a transformation KOP. Are the panels tongue and groove? Looks great.
Yes I get the panels hydrolocked when ordering it takes two people to do the job and it can easily take a 5 days to just do the paneling in a whole bathroom , and you really need the proper equipment stands to support the panels and a rail saw is a must and gives a nice machined edge, hand saws, jigsaws won't cut it and will chip and damage the laminate a whole bathroom can take 3 weeks+ and costs vary on complexity, your shower I'd say around £1000 to prep and fit out , a whole bathroom can be £6000 - £10,000. Depends on the finish and chosen fixtures and fittings flooring , ventilation and electrical work . Kop
Have to disagree there's never over kill where showers and trays are involved the prep is the most important part of the job, I do at least 10 - 20 a year and from reading the ops description of what's he has I'd seriously consider it ?
I wouldn't personally use a 3 mm board for showers , I'd use the thicker 9 mm cellular shower boards for a more affordable job , l'm starting one on Monday with Multi panel my favoured product. Kop
Hi KOP. May I ask, why would you not use the 3mm boards. Can you elaborate please?
If there is going to problems during installation, I would prefer to know before hand, especially if you have advice on how to work around any potential problems.
Your advice would be much appreciated.
Here we go shower bath removed , tiles stripped now working on the prep on the walls this one will have a raised tray to accommodate the waste , first fix today before multi panel later this week 😉👍. Kop
Ooo you’ve second-handed that bath somewhat!
Nice little job those, please report on how your multipanel turns up mdf/ply.
It ply mate I checked but your right they are going over to MDF big mistake it's been tried before and failed , looks like it's Dura panel from now on not so many pattern choices but they won't be changing to MDF
Got the panels and shower fitted up graded the extract fan replaced flexs and grilles , plumbing alterations to do today customer is now away for a few days so a bit easier
Shower tray to fit , then shower doors going in .
Can't carry on with the rest till the new year as committed elsewhere, this week was the only spare time I had between now and January busy busy. Kop
Interesting that you fit the boards before the tray? Makes that a lot easier!
But doesn’t it result in a large silicone seal at the bottom to get over the tray radius?
Reply to Shower tray sealing tapes in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
I've got an issue with the shower tray not being totally flat. As you can see from the photos, it is about 7mm out at one side. It's leaning...
Hi, I am looking to install a Mira flight shower tray 760 by 760. I would have like to have removed the existing floorboards and installed battens...
2K
The situation is as follows. I have a shower enclosure which is slightly too small for the new shower tray. In a way this works to my advantage. I...
Hi there, I'll soon be installing a SONAS 1500 X 800 resin shower tray in a bathroom that I am renovating. It does not come with any sealant or...
2K
Hi Just moved into a house and in process of renewing sealant around the shower cubicle. Feel free to skip to the bottom to get the question...
