Discuss Setting Altech ALTHC04 to manual in the USA area at PlumbersForums.net
Hi all
Just moved into a house with valiant boiler and Altech ALTHC04 thermostat. Is there a way to set it to demand only, I only want the heating on when I need it not on timer
It's a room thermostat. Set your boiler to on and use the down arrows to drop temp down. When you want heating on then it's up arrow to above current temp.
Thanks for reply
I've tried that seems to have a mind of it's own coming on and off when it wants cant figure it
Its a re badged salus soil by Graham's instructions readily available online from memory its hinged on right hand side short instructions inside!
Press UP and DOWN at the same time and it should switch Off (Sleep mode) and turn the display off.
Press any button to turn back on.
How do you just get it to turn the f ing heating on. Over riding the stupid programmes timers. Just a manual option to turn heating in and off. Such a piece os s
Reply to Setting Altech ALTHC04 to manual in the USA area at PlumbersForums.net
Hey folks, I'm in a bit of a pickle trying to set up my hot water and central heating systems. Got a gas boiler with a pressure tank and a motor...
Hi wonder if anyone can help. Had no issues last year. Have Valiant ecoTEC plus and Drayton thermostat. I have tended to leave thernostat and...
Hi I am somewhat confused. My daughter has a combi boiler bought 2-3 years ago and has it timed to come on in morning for an hour and at night...
Hi, I have a Worcester Bosch Greenstar 30Si combi boiler, the analog clock has stopped and the On-Timer-Off switch only works on Timer setting...
Am I the only one struggling to find appliances' manuals online? I know it's hard enough with cookers and old gas fires but I've just been unable...
