Discuss Setting Altech ALTHC04 to manual in the USA area at PlumbersForums.net
Hi all
Just moved into a house with valiant boiler and Altech ALTHC04 thermostat. Is there a way to set it to demand only, I only want the heating on when I need it not on timer
It's a room thermostat. Set your boiler to on and use the down arrows to drop temp down. When you want heating on then it's up arrow to above current temp.
Thanks for reply
I've tried that seems to have a mind of it's own coming on and off when it wants cant figure it
Its a re badged salus soil by Graham's instructions readily available online from memory its hinged on right hand side short instructions inside!
Press UP and DOWN at the same time and it should switch Off (Sleep mode) and turn the display off.
Press any button to turn back on.
How do you just get it to turn the f ing heating on. Over riding the stupid programmes timers. Just a manual option to turn heating in and off. Such a piece os s
Reply to Setting Altech ALTHC04 to manual in the USA area at PlumbersForums.net
Pipes for thermostat shower have been fitted at different heights. Any way of rectifying without ripping all tiles. So for clarity 15mm pipes...
I have an ideal vogue max S18 boiler and I’m considering fitting auto balancing TRVs, my question relates to the boilers pump. I see a boiler...
Hi All, does anyone know why the water only fills 1/3 of the way please?
