• Thread starter T & H Plumbing
  • Start date
  • Replies 15
  • Views 125
  • head
Discuss scratching my head.... in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Take the radiators off and open the valve into a bucket to see if you have any flow of water, if there's nothing then it's probably gunged up.
Is it microbore by any chance?
As above, check both valves flow. Don't forget boiler will need toping up. If the pump is I side the casing, no your not aloud to change the pump.
It's a combi Valient ecomax
It's coming up in 15mm
And yes the pump is incased
15mm should be ok usually. Still worth checking the pipework and radiator before boiler pump.
Thanks chappy ill do that first thing just a bit gutted I couldn't sort it today tried everything
If the pumps okay, You could also check that the Diverter is not bypassing to PHE when its on heating, effectively taking the ''ummmff'' out of the pump and not letting it get to the furthest rads.
Rad valves are always a good bet
Reply to scratching my head.... in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hey folks, I'm in a bit of a pickle trying to set up my hot water and central heating systems. Got a gas boiler with a pressure tank and a motor...
I have a downstairs rad that has a 23 year old TRV and it's barely heating up. I bled it, and removed the TRV head and it still just gets a bit...
I have a Glowworm Ultimate 35C boiler. It shuts off at its max temp of 60C when heating radiators and the pump carries on running pumping heat...
Hi, whenever my Gloworm 18r is on even if I leave it on non-stop for 6 hours the flame symbol for the burner never switches off and the radiator...
A (if) CH system has a very high head loss due to improperly sized pipework and long runs and possibly partially blocked pipes and requires a UPS2...
