Discuss Saniflow repairs yes or no? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Paulus
I have searched through all posts on Saniflow toilets and can't find an answer.
Customer phoned today to say her saniflow has been making more noise than usual recently and the pump seems intermitent.
Have any of you guys had experience of stripping one of these down? I have agreed to have a look at it tomorrow but am now getting cold feet as I don't fancy getting covered in the old brown stuff and I don't want to cover the customers bathroom in it either.:38:
Should I advise her to get a Saniflow engineer in?
Any advice would be greatly appreciated.
If the unit is working it should not be that bad inside,just maybe a crust covering here and there.so should not get over other parts of bathroom,the hardest part of the job is getting the lid back on when you have finished
If more noisy than usual, maybe something has been put down it, that shouldn't have been,there is a inner cage over macerator section,so maybe something in there
imho
I've not taken one apart but from what I understand get a wet vac and Hoover it out!
I've done one. The cust poked a net curtain rail down it and lost the spring. Jammed it good and proper, got it out but unit didn't last long after that and had to fit a new one.
The upshot of my first encounter inside a saniflo is the fact there won't be a second.
so youve had a number one and a numbe two on a saniflow simong ?
imho if there out serious dont bother repairing there more agro then there worth, simpley replace
i have stripped down one, have had a worse toilet blockage if i'm honest. They look relatively easy to repair also if you do boiler repairs then you'd understand the mechanics of a saniflow no problem
Many thanks guys, I'll give it a go and let you know the outcome.
Assuming I survive.
Agreed, I once spent a good hour cleaning a blocked saniflo out on a patio. Toilet backed up with brown soup etc, removed sanifo and scraped it all out into a bin liner while wretching the whole time. Got it all cleaned up and checked the 22mm pipe and it was clear so re fitted.
Did it work? No
had no real big probs doing them,as said drain blockages can be a lot worse
Did one a few years ago,full of condoms rapped around the motor,must of been hundreds in there,did not know what to say,incase wife on pill and maybe a bit of playing away going on,so bagged um up,lasted well,still using them today :1:
Reply to Saniflow repairs yes or no? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Had a call to a 82 Old man, he paid these £300 up front for a years cover, and I find out on arrival he's been waiting for 3 weeks, no heating or...
J
Hi all, I am a plumber but I do not carry out works to boilers as the majority of my is bathrooms so I am not gas safe. I have completed a...
I have just moved into a late 1990s new-build house with a small bore (about 1/2" OD pipes) gas fired boiler central heating system. All the...
Hi Everyone, For those who like a long read but I could rally do with some advice. Might be a bit long this. For background. A...
Forgive my ignorance, with this basic question, but I seem to be struggling to both understand, search for, and source, the appropriate washer...
