Discuss safety valve on insert stove in the Plumbing Jobs | The Job-board area at PlumbersForums.net
T
toiletpan
can anyone please tell me where i should install the safety valve on a insert stove as the stove will be totally inclosed i know that the valve needs to be as close to the boiler as possible many thanks
Safety should not be necessary if the stove is properly plumbed using a F+ E tank.
Do not try to connect to an existing pressurised / sealed system without making the necessary changes to the system, a standard PRV is Not enough for solid fuel.
i will be connecting to a existing open system and thought a safety valve would be a extra precaution many thanks for your input
Reply to safety valve on insert stove in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Is it possible to install a wood burning stove with an air to water heat pump? I was speaking to a few plumbers who have said this is not possible as the air to water system is a pressurized system and the stove needs to be in a vented system.
I have a thermal store heated by a boiler with its own thermostat. I also have a stove with a back boiler. The stove heats water in a separate tank. There is a thermostat on this second tank that pushes hot water over to the store tank when it's hot. It's a closed loop and goes through a heat...
I have Honeywell Valencia TRVs 10mm pipe size, I’m making mods to accommodate larger rads and it looks like the 10mm compression insert is special to Honeywell as all available inserts are 15mm to 10mm which do not fit as the compression nut has a 10mm hole, not a 15mm. Anyone know if you can...
Can anyone please tell me where I might purchase a 90° bend 15mm x 22mm Isolating Valve Thanks and Regards. Hugh
Hi. I have a kitchen mixer tap unit with older washer type inserts which has a dripping cold side. I have a pair of replacement ceramic inserts to upgrade both but the cold side insert will not shift at all. It genuinely is so tight that I am in danger of damaging the mounting even though I am...
